50 Tooth Rear Sprocket?
Old Oct 31, 2007 | 11:16 PM
bryantjt's Avatar
Default 50 Tooth Rear Sprocket?
Can anyone tell me if a 50 tooth rear sprocket will fit with the lower chain guide? I know I'd need a longer chain but I'm just wondering as thats what's mounted on my spare wheelset that I'm purchasing tomorrow.
Old Nov 1, 2007 | 12:35 AM
Default RE: 50 Tooth Rear Sprocket?
I know 49 fits as I ran one briefly. If 50 doesn't, it will probably rub the lower chain guide just a bit, maybe not enough to worry about, but I haven't actually tried it or seen one mounted personally.
I had a 52 mounted on my KTM, but I guess that doesn't do you much good, huh?
Old Nov 1, 2007 | 03:37 AM
warski's Avatar
The 50 will only fit after you spend about 5 minutes with a dremel. It's simple, do it!
The short answer to your question would have been; no, it doesn't fit.
Check my signature line below...
Old Nov 1, 2007 | 04:53 AM
kgwld1's Avatar
I spent 5 min with a cut off tool to get it to fit. I don't post much on here anymore due to a tool that post on here, but I can now ride 4th gear power wheelies and love it.
Old Nov 1, 2007 | 04:58 AM
stellar_d's Avatar
ORIGINAL: kgwld1
ah cmon man dot let one guy ruin it for us, information is critical!
Old Nov 1, 2007 | 05:00 AM
ORIGINAL: kgwld1
Hey Ponch..... what up, good to see you again.
Old Nov 1, 2007 | 05:29 AM
kgwld1's Avatar
I shouldn't let one guy ruin my fun but sometimes its hard.
Old Nov 1, 2007 | 05:32 AM
MaverickAus's Avatar
only sometimes? [&:]
[8D]
Old Nov 1, 2007 | 10:39 AM
bryantjt's Avatar
Thanks fellas, I'm thinking the black slider needs to be worked over a tad?
Old Nov 1, 2007 | 11:18 AM
No josh its probably the rear chain guard on the lower part of the swing arm.
