2nd accelerator cable
Old Jul 6, 2012 | 06:08 AM
Pogiboy's Avatar
Default 2nd accelerator cable
Anyone removed the second accelerator cable? Removed mine and I noticed more snappy throttle return and better throttle response. Haven't tried riding bike due to injury.
Was thinking this is the same principle if you changed to aftermarket throttle grips which only uses 1 cable.
Old Jul 6, 2012 | 06:19 AM
toyotabuilder's Avatar
its for push pull throttle and usless on this bike but on another note i think your but dyno is off becaose it doesn't change power delivery to unhook it, and as far as throttle tubes some people cange them to get the throttle to open quicke with less rotation, i put a protaper on because it has bearings in the tube and is silky smooth
Old Jul 6, 2012 | 02:30 PM
Recently discussed: https://www.kawasakiforums.com/forum...s-point-38335/
It's possible your return cable is sticky or such and may have been putting some drag on the pull cable. Other than that there's no effect.
Old Jul 6, 2012 | 02:45 PM
Blackheart58's Avatar
If your pull cable broke on the trail, could you scavenge the push cable to be used as a pull? I haven't looked at the ends to see if they are the same, but, I imagine they would be....
Old Jul 6, 2012 | 03:10 PM
Pogiboy's Avatar
Thanks. I think i will keep it off. I like the feel. My idle problem is also gone.
falcn
Aug 9, 2014 07:21 AM
red
Jul 29, 2011 10:49 PM
ol guy
Sep 29, 2010 06:45 PM
albany551
Nov 20, 2009 01:36 PM
BVOYTEKB
Apr 25, 2007 05:06 AM
