2010 KLX250s Wont start unless you give it gas
Title says it all. My bike won't start unless you give it gas. Its not a huge problem because once it does start it idles great and runs great. Even after its warmed up quite a bit it still won't start on its own. Only after you give it throttle. Any suggestions on what could be the cause of this. The bike is a 2010 and has 3500 miles on it and has been doing this since we bought the bike at 1500 miles. Thanks
Has the carb been re jetted??
Rich jetting on the pilot jet can cause this can cause this. |
Mine does the same thing and the previously mechanic jetting the carb too rich I think. I got the kdx snorkel and full exhaust going on this weekend, im debating if it needs to be rejetted after or not since its so rich
I would pull the bowl off and take a look. Some people know how to rejet and others think they do. Let's us know what you fine.
I'm not to good with carbs so i'm gonna drop it off at the shop for them to verify
Yah I'm not good with carbs either. I do not think it has been rejected though.
my bike 2012 brand new would not start without gas
and if it sits for 6-8 hrs san diego weather you need to pull out choke to start 10,000 miles later, couple mods still need to give gas to start and still choke it too its not fuel injected and I don't recall any carb bike I ever had start with no gas |
Is your carb rejected? I'm going to get the dyno jet kit a upgraded air filter and a full exhaust system as soon as my next paycheck comes in
Originally Posted by ReptiMoto
(Post 530867)
yes its rejected and I even went the extra step and used a wideband meter to dial the jetting in exactly how I wanted it but like I said the bike acted the same way it is now, when brand new all stock never started without giving a twist of the throttle and if sits for over 6-8 hrs even summer day will need some choke to get it started Years ago I had a dry 400s did the same exact thing too |
That sucks, I think mines that way too. The only reason it's a pain in the but is when I am on a really steep dirt hill and need to start it. I then have to hold the front break, press the starter button, and twist the throttle at the same time.
