2009 w/ oil leak at cylinder head cover...help
#31
Just completed this Job of replacing the Head cover Gasket. Fairly easy job. The only issues I had was a ruptured gas line and all the tubes surrounding the cover. It is best to get a new gasket because the old one will not fit again once it is removed. Used Three Bond Liquid Gasket 1194 to seal it.
#32
Old Thread I know but.. Put me on the 09 leaky valve cover list..
Yep 3400 miles and the R Frt half moon is weeping.. Dammit
Well I jumped on here and guess I will get a NEW gasket and go from there..
#33
The new gasket seemed more pliable and "rubbery" but then again the old one was 5 years old.
#34
When I did the cam mod I couldn't get the old gasket back on. So I superglued it to the valve cover just enough to get it on. Then used gasket seal on the half moons. Months later, no leaks.
#35
Yep didn't plan on this. Don't know but seems like a bad design..
I'm going to look at this carefully and see If I can make a different gasket..
A friend of mine has a race shop for cars and Motorcycles.. He makes gaskets all the time out of that aluminum metal Felpro material.. So hmmm will see what he thinks.. I don't know just got to be a better solution.. Will see if so I will let everyone know
#36
The gasket on the '09 shrinks period. After doing the big bore, you find out real quick. Be smart order a new gasket ahead of time. I noticed the new one doesn't shrink either after doing a couple valve clearance checks.
#37
Agreed with RaceGass, just go buy the gasket. Your buddy might make gaskets for projects, but this isn't a simple flat-surface to flat-surface gasket fit. By far, the 'simplest' thing to do is buy one at the dealer.
#39
the 09 year is known to have bad gaskets. other years and replacements dont appear to have the issue since kawasaki fixed the problem.
