2003 klx d-tracker
Old Jan 15, 2018 | 09:54 AM
Donovan de Jongh's Avatar
Default 2003 klx d-tracker
good day fellows
i have a 2003 klx d tracker but have resently got a 2006 motor and am in the prosses of changing over the motors only thing i found is that the carburetor has a T section on the bottom of it with 2 hoses coming off it that used to go onto the motor and as well as the engine wires arnt the same plugs that plug into the computer
could someone please advise me on the situation or is the 2 not compatible? any help will b apprishiated
Old Jan 15, 2018 | 02:56 PM
Can you post a pic? I'm not following the "T section".
I don't think the electrics will make a difference. On my '06 KLX250, I understand that carb TPS was supposed to impact timing, but it didn't. I couldn't notice a difference when connected or disconnected. I upgraded to a pumper carb with no TPS and it runs just fine.
Old Jan 16, 2018 | 08:51 AM
Kwak's Avatar
T-section most probably is carburetor de-icing circuit connection. You can remove de-icing circuit.
Donovan de Jongh
Nov 18, 2017 07:11 AM
Topaz
May 25, 2009 02:20 PM
tremor38
Feb 11, 2009 10:44 AM
WestOzKLX
Apr 21, 2008 06:54 PM
archive
Mar 4, 2008 08:04 PM
