2003 Klx 250 d-tracker
Old Nov 14, 2017 | 09:19 AM
Donovan de Jongh's Avatar
Question 2003 Klx 250 d-tracker
Hey guys and girls
iv got a 2003 klx 250 d tracker with a piece of the cam chain tensioner that had broken off and fallen into the motor I'm currently looking for a new or refurbished motor but seem to b a hard task to accomplish
in found a 2007 klx 250 motor but unsure on the if there are any changes between 2003 and 2007 in the engine manufacturing
Help would b apprishiated
Old Nov 14, 2017 | 10:10 AM
klxnoobie's Avatar
Not any significant changes should bolt right in.
Old Nov 14, 2017 | 10:42 AM
durielk's Avatar
If the motor just has a broken tensioner, getting that fixed should not be too complicated.
I have a 93-96 manual and mostly the same as my 07, except for the kickstart I think.
Old Nov 14, 2017 | 05:33 PM
Thanks for the help
I have replaced the tensioner but when I pulled the old one out a peace from the tensioner had broken off and fallen in the motor and it making a grinding noise so I think the damage is already done
Old Nov 14, 2017 | 07:27 PM
Pull off the right side cover and see if the part is in there. I had the spring from the compression release take a trip down into the bowels of my KLX 650, found it a bit the worse for wear when the top end was torn down for worn cam chains and burnt valves. The bottom end is still together about 20,000 miles later. Bits like that usually end up in places that won't trash an engine. I think the design is such that it should be in the side case, maybe grinding against something there. it is too big to get into bearings. Worth trying for sure. Take a look - less costly than another engine.
Old Nov 18, 2017 | 07:11 AM
That's man I apprisiate it will get onto it!
panaisnc30
Apr 15, 2013 10:23 AM
superzaxos
KLX300R
Jan 20, 2013 10:42 AM
yankee99
Sep 12, 2012 08:03 AM
core.ribeiro
Aug 10, 2011 04:18 AM
archive
Mar 4, 2008 08:04 PM
