2 bros and fmf megabomb header
i got a 2 bros slip on . is there anyway i can make a fmf mega bomb header work with the 2 bros slip on pipe?
pics would be very nice thanks |
i heard it does and doesnt. i can remember. but ill sell you a whole two brothers for $200 plus shipping!
I ran that exact combo. Went together no problem.
sweet so it dose fit then? thanks for the info
Originally Posted by Back Trailin
(Post 427243)
Mine did not fit fine...I had to cut some slits in the M7's pipe to allow some expansion for the PB to fit into it.
If you can create a taper on the FMF header, the 2 brothers will slide in. My mechanic made a tool from brass to flare the header pipe, and used high temp silicone with no clamp. Hasn't leaked yet :)
mega bomb has to big of an expansion chamber.. you dont get enough back pressure= slowwwww.. go with the power bomb or klx 300 header
My FMF power bomb/M7 combo did not fit properly... went to a local muffler shop where some of the mechanics twist throttles, take both units so they can expand the M7 flange to slip over the FMF header approx. 1 1/4'', that will ensure a good leak proof joint! Good luck... remember "no falls... no balls!"
