'10 KLX250s with KLX300r exhaust question
Hi, I've been reading a lot lately to find the best cheap mod for my KLX. I'm kinda low on cash lately but would like to get a little more out of the bike. Decided I was gonna go with the KDX snorkel, Dynojet and probably put a 44 or 45 rear sprocket, don't wanna lose to much high speed. Exhaust mod are expensive but I found a used stock KLX300 complete exhaust system for around 200$ and was wondering if it was worth it. Do you think that I will see a 200$ difference or should I stick with the snorkel, Dynojet and sprocket mod?
Thank You |
I put a complete stock KLX300 system on my bike. It defintely made a difference. A $200 difference? I don't think so, but I guess that's up to you. You can find them much cheaper than that. I'd think you could find a used aftermarket slip on for around the same price or less, and have as good or better power.
I bought mine for $45 and thought is was very worth it at that price. The main advantage over most aftermarket systems is that the OEM pipe requires zero maintenance. |
I feel as though I am very much in you shoes sebnad, because I too will be buying an exhaust system soon; along with some sort of airbox mod and a jet kit... but at 270 shipped for a FMF, its only 70 bucks more and your getting a much better looking/sounding(arguably) exhaust, even if it is not the full system I bet it would be similar to the full klx300 setup at least in terms of flow.
As far as the OEM pipe requiring zero maintenance I will agree for the most part, however my service manual recommends removing the carbon plugs on the exhaust and tapping the muffle lightly with the engine running to loosen sediment buildup in the exhaust from time to time (not saying there ever is). |
$200 is too much for a stock exhaust, I'd go with used or new aftermarket.
Originally Posted by LikesToThump
(Post 457050)
... but at 270 shipped for a FMF, its only 70 bucks more and your getting a much better looking/sounding(arguably) exhaust, even if it is not the full system I bet it would be similar to the full klx300 setup at least in terms of flow. ...
Bottom line: an aftermarket slip on for a 250S will be on (at least) the same level performance wise as a full stock 300R system. On the zero maintenance aspect you're correct: the manual does call for removing the plugs...but like you say, there's never anything there anyway. |
(Post 457050)
Are you trying to keep the bike quiet too? If so, that may be a good reason for the 300 muffler and snorkel. If you don't mind some noise, a used aftermarket slip-on may be found for a bit less.
I'm running an HMF slip-on picked up for around $140 ttl from fleabay. Instead of the 45 rear sprocket, which may require a longer chain, how about switching the front from 14 to 13? One tooth on the front is about equal to 3 on the rear. That should save a few bucks. And you could try the stock snorkel removed or lid off while you're jetting. |
Originally Posted by IDRIDR
(Post 457072)
If you are going with a power bomb you might want to get a heat shield to save you riding pants/leg.:D
http://turnsleft.smugmug.com/Other/2...IMGP0785-L.jpg |
Don't waste your money on the snorkel, and get an aftermarket exhaust.
The end. |
