09 klx 250 shifting problem
I have an '09 klx 250s that is in neutral and will not shift into gear. The shift lever will move and is still spring loaded but no gear will engage. Was doing some trail riding in first and it seemed like it was in second, shifted to neutral and that was it. No noises or anything. Any ideas??
Lets get the facts. Will it no longer go into first gear, or are you having trouble getting it into first gear but it will still go in? Are you stopping in 2nd or 3rd? Because if thats the case then you have to pull in the clutch, push slightly on the shifter and let the clutch out half way and it will pop right in. Let us know what the dealio is.
Oh I see that was your first post, so Welcome to the forums! Is this your first bike? Post up an intro in the new members area, and tell us where you ride or live and what your experience level is.
The oil is fine. I change it often. With the clutch in and rolling the bike, it won't go into any gear. The shifter feels normal (spring loaded) but nothing catches. It's just in neutral.
Is it the same for clutch out and rolling the bike (engine off)? Or will it go into gear then?
It won't go into any gear with clutch in or out with engine started or off. I'm not the same guy from ADV. It seems as if the connection from the shifter shaft to the shifting forks is nonexistant.
