07 KLX250h NO SPARK
Old Oct 15, 2024 | 05:08 PM
jerwin0196's Avatar
Default 07 KLX250h NO SPARK
Hey guys. new to the forum. I just acquired a 07 KLXh and it has no spark. I've tried everything I can think of with absolutely nothing to show for it. I bought a .pdf repair manual (cyclepidia) and have tested stator, pick up coil, ignition coil, and they all bench test (ohms) fine. I even replaced all the above tested items just incase they tested fine but were faulty.....still no luck. Bought a used cdi (I C igniter) off ebay, still nothing. pulled the entire wire harness off and check EVERY WIIRE to see if there was a break some where, everything was fine. Cleaned up all the grounds and connecters, put the harness back on the bike....nothing. Anybody have any suggestions before the bike finds its way to the scrap yard?
Thanks!
Old Oct 19, 2024 | 11:29 AM
doum's Avatar
On mine, I had to replace the kill switch, it was unreliable.
Old Oct 19, 2024 | 11:33 AM
doum's Avatar
Also, does your neutral light work? If not the kick stand swith also need to work (or be shorted) for the bike to start.
I.E. it need to be in neutral or be off the kickstand to start.
Old Oct 20, 2024 | 11:28 AM
jerwin0196's Avatar
Yes neutral light works and is on. Kick stand switch was also tested. To be honest i never looked into the kill switch. I assumed it wouldn't turn over if the kill switch was bad.....ill look into that
Per
Aug 18, 2024 05:26 PM
smoothops
Classic Sportbikes
Jun 25, 2020 10:54 AM
Rocco H
Oct 24, 2017 01:53 AM
Branderson92
Feb 9, 2011 10:55 PM
davebrodeur
KX65
Sep 13, 2009 07:54 PM
