06 klx250 ignition advance
I'm interested in advancing the timing on my 06 klx.
I've found playing with my tuner car that ignition makes a bigger difference than afr.
Does the 06 use a cam sensor like the newer bikes?
Is it adjustable/
Has anyone played with this before?
thanks
marc
Is it adjustable/
thanks
marc
Ride on
Brewster
I know very little on this, but I believe that someone posted an offset Woodruff key that was designed for advancing the timing. Kind of a work around.
Dan
Here's one
Tyga Performance - Woodruff Key, Offset, 4 Degrees, NSR250 - High Performance
Dan
Here's one
MSD makes a single cylinder CDI and they have a tech forum (click) where you can ask questions.
MSD Powersports Universal CDI Programmable Single Cylinder Ignition 4217 PC Programmable, high output ignition Create a timing curve with up to 20 points across the engine RPM range Accepts magnetic pickup or hall-effect plus rigger inputs Program a rev limiter for the launch and one for over rev applications 12-volt battery source required Single Cylinder Prog.
