06/07 vs 09+ Stator cover?
So I damaged the stator cover case on my 07 today practicing wheelies. I'm JB welding it for now.
Does anyone know if the 09+ cover(PN 14031-0110) will fit on the 06/07 bikes(PN 10431-0042)?
edit: I'm seeing the cover gasket is the same part number, so the covers must be the same.
The gasket used for the cover has been the same for all the electric starts and I think even some others, including 300s. So the 09 cover should fit case to case, I doubt the over all shape has changed since it's simply the stator cover and I doubt the stator has been re-engineered in the past 20 years. It has to be the electric start cover though. And again the gasket shows the cover fits every electric start 250 from 06-20. The number change for the cover is very likely because of the finish on the cover, not the actual shape of the cover.
but I'd still see if I could find a good TIG welder and have them weld it up. Someone who can make a fine bead. Takes a seriously good welder because of the small part, no big gobby welds that affect the fit. I will also say I think the JB Weld may work, but kind of risky if inside should it peel.
I tried to JB weld it for the time being but it seems to be leaking unfortunately. I cleaned the whole part, sanded it, and used JB weld original on both sides. Let it cure for 24 hours(at 28C), and no dice.
I think you are right. The only difference(aside from colour) seems to be that the 06/07 cover has "Kawasaki" embosed on it, and the newer ones are smooth.
