***an updated faq, ride reports, quick links & good all around noob information***
Frequently Asked Questions
Disclaimer: While all due care has been taken in the compilation and editing of these FAQs, you attempt any of these additions, modifications or maintenance work at your own risk. If you doubt your abilities to perform any of the work discussed in this FAQ, you are strongly advised to consult a professional mechanic to carry out the work for you. No responsibility or liability is accepted for any information contained in these FAQs. This FAQ is a joint effort by members of this forum and is not endorsed by Kawasaki Motorcycles. Having said that, with the right tools, a willingness to learn and a modicum of patience, you should be able to easily perform most of the work discussed here by yourself. If you have further questions, don't hesitate to post them to the appropriate forum. !! Under Construction !! NEW UPDATE AS OF 4/15/08 Here are a few more quick links to great information. Thanks Nobrakes for the help. KLX250S Section Sticky Thread Index New Members Start Here: Forum Rules Reminder: https://www.kawasakiforums.com/m_61283/tm.htm More Frequently Asked Questions: https://www.kawasakiforums.com/m_32156/tm.htm KLX Community Photobucket: https://www.kawasakiforums.com/m_98590/tm.htm Common Part Numbers : https://www.kawasakiforums.com/forum...-numbers-3437/ DirtSurfer's Mod Day - One Stop Shopping for Mod How-To's with photos: https://www.kawasakiforums.com/m_100000/tm.htm johnnyz62's KX fork conversion : KX Fork Swap Nearly Complete - Kawasaki Forums Marcelino's CAM Mod: https://www.kawasakiforums.com/forum...rcelino-35904/ Mods and Other Information from the ADVRider thread : https://www.kawasakiforums.com/m_213768/tm.htm (NEW) KLX250s FAQ and links KLX250s FAQ and links - Kawasaki Forums Ride Report Index : https://www.kawasakiforums.com/m_233842/tm.htm Put Yourself on the Map https://www.kawasakiforums.com/m_32803/tm.htm Tips: How to Deal with Difficult Members : https://www.kawasakiforums.com/m_187406/tm.htm |
