hard starting on new bike
Old Jan 5, 2008 | 12:56 AM
klx250smass's Avatar
Default hard starting on new bike
I have an 07 klx with only 150 miles,, I do not ride it alot, but after a week or two of sitting I can't get it to turn over. The dealer picked it up and cleaned the carbs,, it started fine, now two weeks later it will not turn over,, it just cranks and cranks,, any tips here?? I am into basic fixes only. dealer has to handle anything complicated. thanks
Old Jan 5, 2008 | 01:16 AM
Default RE: hard starting on new bike
Hey man congrats on the new bike, welcome to the forums and here you go. Looking forward to getting to know you better.
https://www.kawasakiforums.com/m_96672/tm.htm
Shut down procedure.
1. After riding as you are pulling into your driveway, or to speed things up you can do this a block from your house, turn off the gas.
2. Let the bike run until it actually dies from gas starvation, (this may take 2-5 minutes) But that's ok it will give you time to put away your gear.
3. Park it and now you're ready for the next time you ride whether that be in a day, or a month.
Start up procedure.
1. Turn on the gas
2. Wait for 10 seconds
3. Start the bike as you always do
Now I know some of you are asking why not just drain the bowl and then you can start the bike. Well there are two reasons. It it harder to drain the bowl by hand than to let the bike do this as it runs out of gas, and by running the gas out using the motor, it assures that all of the small areas that would otherwise still have this junk they call fuel will be empty, ready for fresh, (fresher) gas to get in and do its job. Now all of that being said, I came up to work yesterday to let my son ride the moped up on the lawn and I cranked on the bike for a few minutes, and then I thought I wonder if I can drain the bowl and do the "after thought" procedure to get this thing going? Well I drained the bowl, turned the gas back on and two kicks and it was running. Keep in mind that the moped is a two stroke, and it has been sitting up at work in a mechanical room for about 2 months. So either way, whether running the gas out using the motor so you are ready to go next time (which I think is faster and more efficient) or you drain the bowl using the screw at the bottom of the carb, the results are the same, you get your bike started.
And I even guess some people would say that this is a hassle, but I gotta tell you that cranking on a bike for 5 minutes off and on only to run the battery down and still have not started the bike is way more of a hassle than a little time taken to get ready for the next ride. This last summer I rode my bike everyday for about 3 months, and it always started right up, but there are a couple of reasons. one it was warmer out, cold weather affects fuels in a negative way, and more importantly by riding the bike everyday I had gas in the bowl that didn't have enough time to "change". Next summer I will probably go back to leaving the gas on and not draining the bowl. but on the wife's bike the procedure will always be to run it out of gas since she doesn't ride as often as I do.
Old Jan 5, 2008 | 01:12 PM
thanks for the reply , I will drain the carb and clean it out today and see if I can get it started.
Vert1go
Oct 8, 2011 12:50 PM
LeftyS7
Nov 20, 2006 06:27 PM
LeftyS7
Ninja 250R
Nov 6, 2006 03:57 AM
NORMAN VITRANO
Aug 30, 2006 12:50 AM
roadrashdave
Nov 7, 2005 08:51 PM
