Fitted lowering links but have a problem
The links arrived fine and fitted to my KLR 250 it has lowered the bike nicely, but the suspension goes down ok but there is no upward movement ? do you know what that could be? The only thing it could be is in its life it may have had a KLR 650 shock fitted, I am unsure if that will make a difference or not, anyone know what could be the problem not having any upward movement on the suspension?
Regards Mick |
What do you mean no upward movement?
The shock is packing down and not rebounding? The bike is not raising up when unloaded as high as it used to be? What? |
Originally Posted by klx678
(Post 525726)
If anyone wants to swap a klr 650 shock for a klr 250 shock I would be pleased to swap
Shock is topped out. Probably too much preload on the spring. No fault of the links or the bike. Back the preload down on it if needed. My KLX650 only sags about 1" and the rear is pretty soft. I would guess if I cranked it up to max there would probably be little or no sag.
(Post 525760)
If the rear suspension is too stiff that is exactly what I am saying. I am not familiar with the KLR shock, but if it has the large lock ring set up you can soften it up a bit, but I'd ride it first.
I believe sag is usually the amount the bike sinks when you sit on it and it probably should be an inch or two for a guesstimate. If it sinks an inch or two I'd just ride it and see how it feels. If it feels right I'd leave it as is. This appears to be a common swap on the KLR250 to get a better suspension set up so you may want to learn more about it and stay with the better shock. There is nothing wrong with your set up it just has enough spring to hold the rear end up at full extension, no big deal. |
Nice video, I will have a look at it tomorrow and see what's it like, if I can get it started, been a nightmare to get it running, wonder what's best choke setting from cold ?
Usually full choke, no throttle. Drain the float bowl first if it has been sitting for more than five days. Fresh gas in carb fires easier. My KLX650 will not fire if the gas in the carb is over 5 days old, my 250 will get hard starting if over about 10 days.
I will give that a go today 678 cheers
