Engine stripdown
Hi, i have found some white stuff in my oil and water, methinks the gasket has gone, can you tell me if it is possible to replace the offending gasket without removing the engine from the frame.
RE: Engine stripdown
What gasket are you suspecting, head gasket?
Just remove the fuel tank and you can do the R&R of the head gasket without removing the motor from the frame. |
