KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
Please help with choke issue klx125
Old 04-22-2017, 07:53 PM
Amn28210's Avatar
Default Please help with choke issue klx125
This is a 2005 klx125 4 stroke.
Hi I really need to help with this carburetor issue I am usually good with carbs but I have not run into this issue previously l. the choke is not working properly. Instead if being normally pushed in and needing to be pulled out for engagement, it's the opposite. The choke valve is pulled out and you have to push it back in via the lever and hold it there to disengage the choke, which obviously you can't drive it while holding the lever all the time. Does anyone have any suggestions ? I doubt a carb rebuild would solve this issue. Thanks
Last edited by Amn28210; 04-22-2017 at 07:53 PM. Reason: Forgot to put info on the bike
Old Mate
KLX125 & KLX125L
07-20-2017 10:40 AM
hybridized
KLX125 & KLX125L
08-10-2015 01:53 PM
Captain Kuhle
07-24-2011 05:41 PM
WestOzKLX
04-21-2008 07:23 PM
robmac
07-12-2007 07:33 PM
Quick Reply: Please help with choke issue klx125
