Brute Force 750 V twim (2005)
Looking for information regarding 2wd and 4wd switching back and forth on digital display. Also while this happens and driving downhill the ATV acts like you are in neutral when you let off throttle completely. If you slightly give it some throttle then it stays in high or low range. I believe this is a code it is throwing on the display. I would like to know how to reset codes and if this is the only problem. Thanks rbraithw
