KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
Battery Issues
Old Sep 27, 2018 | 12:21 AM
Gparks46's Avatar
Default Battery Issues
Please help!!!
i have a Kawasaki Brute Force 750 year 2012. I have been having battery issues for awhile. I was thinking it was a bad battery all along until recently. I purchased a new battery before I went camping. I was riding and having a good time. Night fell, my buddy and I was cutting wood in the dark. I left my four wheeler running while having the lights on so we could see what we were doing. About a half hour in, my four wheeler died. I was thinking it over heated so I waited around 15-20 minutes for it to cool down only to find out the battery completely drained.
I have been investigating why this is happening. I have searched the web and watched multiple you tube videos on the whole charging system only to explore dead ends.
Results include: voltage from stator 15.4 volts AC, voltage out of rectifier 16.2 volts DC, voltage at battery 12 volts and dropping constantly while wheeler running. I have witnessed the battery drop to 11.5 volts while running. And yes I reconnected the rectifier. PLEASE HELP!!!!!
Old Sep 28, 2018 | 03:33 AM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
or this one is even more focused:
https://www.kawieriders.com/forum/
Old Sep 28, 2018 | 11:46 AM
Gparks46's Avatar
Thanks, I am new to forums.
Old Mar 26, 2020 | 12:50 AM
Bradlea Wilson's Avatar
Default Having same issue
im having the same issue did you fix yours I’m almost ready to sell this thing tired of messing with it
Old Mar 26, 2020 | 10:40 AM
Gparks46's Avatar
yes, needed up being a burn wire on my stator. If I remember correctly it is a 3 wire system. Make sure you are getting same volts from each wire.
Lasha Kochiashvili
Dec 6, 2018 06:02 PM
corel
Oct 9, 2018 12:50 PM
kdhart5060
Aug 23, 2015 02:08 AM
2006ninja650r
Jul 2, 2014 12:28 AM
kabbage
Jul 13, 2009 05:48 PM
