2012 klx 250t wiring diagram. Sparks once won't start?
Guys new member here in need of some desperate help. My klx 250t won't start it winds over fine and will spark once the first time but not again until it's been turned on and off. I could really use a wiring diagram or help from some more experienced guys.
HELP |
Welcome to KF and bummer on the issues. This is a new ride, so can you just take it over to your local dealer?
Have you done any work on the bike recently?
No warranty it was a write off (flood) it was running fine after for a long time but now won't fire. I hear that the side stands can give trouble like this? Can I bypass it easy? A diagram would be absolutely awesome.
Remove the cover to the kick-stand, you'll see a black box with two wires. Cut the wires and splice them together. Seal them to prevent water intrusion. If I remember correctly, I spliced mine quite a bit up the frame to have less wire hanging down.
| All times are GMT. The time now is 09:15 AM. |
