Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
KFX90 lights
Old 04-01-2018, 12:52 AM
GASMAN77's Avatar
Default KFX90 lights
Bought my son a new to us 2013 KFX90. So far awesome machine (same as my daughters Arctic cat DVX90 both made by Kymco). Was very disappointed with the cheap fake lights. Installed a nice set of led off road lights. This is what it should have come with from factory
Old 04-01-2018, 10:36 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
Old 12-06-2018, 03:15 PM
italyguy01's Avatar
They look great! Can I ask what lights you bought? How did you mount them and where did you tie in the power? Any pictures or advice would be much appreciated. I just got my son a 2009 KFX90. Thanks
Old 12-06-2018, 04:13 PM
GASMAN77's Avatar
Here are the parts I ordered. When u take the plastic piece off that had the fake lights on it there are two screw holes u can re use to mount the leds with brackets they came with. Mounted switch on left side near key and the relay/ fuse under the seat behind the battery.
WEISIJI 10W Motorcycle Auxiliary... https://www.amazon.ca/dp/B01M1Y9G34?ref=yo_pop_ma_swf
Liteway LED Light Bar 500W Wiring... https://www.amazon.ca/dp/B071LFWMTG?ref=yo_pop_ma_swf
Old 12-06-2018, 04:20 PM
italyguy01's Avatar
Oh that is sooo awesome! The stator creates enough juice for these? Do you have it wired to shut off when the bike is shut off, or strictly through the switch? Thank you!
Old 12-06-2018, 04:23 PM
italyguy01's Avatar
Also, did you mount the switch on the fender next to the key? Just drill a hole? Thanks
UltraApple
05-02-2011 10:45 PM
neilaction
09-23-2009 07:56 AM
Black lager
500 LTD
03-29-2008 01:39 AM
djmgyx
08-30-2006 12:54 PM
sup_uni
08-14-2006 06:35 PM
Quick Reply: KFX90 lights
