Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
93 bayou 300 blowing fuses, now not firing
Old Apr 30, 2007 | 07:33 PM
perty boy's Avatar
Default 93 bayou 300 blowing fuses, now not firing
I have a 93 bayou 300 that was blowing the main fuse after riding for a while. I would change the fuse and it would be right back in action. last time I rode it the bike shut off as it always would. I changed the fuse now the plug wont fire. any ideas on where to start?
Old Sep 11, 2007 | 02:25 AM
KLX450R's Avatar
Default RE: 93 bayou 300 blowing fuses, now not firing
blowing fuse was a warning sign. You should have checked the amount of charging coming fom the charging system when unit was running. Unit probably has a bad regulator/rectifier which allowed the unit to over charge and blow fuse. The unit finally got your CDI (brain box) now you will probably need CDI Regulator/Rectifier and new fuse. First thing I would do is to check to see if you have power at the ing switch when replacing with new fuse. If you do then trace the wiring harness after removing the racks and body, for any crispy, chaffed,or noticably burnt areas. If nothing apears to be wrong with the wiring I would suggest the above happened. Sorry to say it's gonna be very expensive.
Hope this helps,
Jody
MaximusPrime
Dec 24, 2012 11:48 PM
geoff59
Nov 8, 2010 01:57 PM
PeacemakerKAW15C
May 4, 2010 01:30 AM
McDuff
Aug 27, 2006 07:04 PM
SVTzx9r
Jul 8, 2005 03:59 AM
