700 reverse override
Anybody know how to defeat the reverse override on a 700 twin? Is the same on a Suzuki twin peaks? Wire color etc...
RE: 700 reverse override
Anybody?
If you follow the wires back to under the front plastic, you should find a pair of connectors that lead to the switch on the bars. Just unplug them and plug the ones from the harness into each other, also you can plug the ones to the switch together to keep the dirt out of them.
