2011 Brute Force 750 Wiring Schematic
Does anyone know where I can get a wiring schematic for a 2011 Brute Force 750? I swamped mine some months ago, and have not been able to start working on it till now. I know what wrong, but need to try and find root cause. One of the injectors is not firing. It has power going to it on the white wire with a red tracer. However, the purple wire coming off of it I need to trace out. If you swap injector connectors, the problem follows the connector. So, I don't think it's the injector. I'm trying to determine if the problem is in the harness or the controller, and the controllers are expensive. I'd like to confirm it's not in the harness rather than doing swapnostics.
