Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
2007 Brute Force coolant flowing straight into crankcase
Old 07-15-2018, 12:00 AM
Apd833's Avatar
Default 2007 Brute Force coolant flowing straight into crankcase
Ok, so I have an 07 Brute Force 750. I noticed it was getting water in the oil, but it was also leaking out around the stator cover. I replaced all of the seals sitting the water pump (mechanical seal, oil seal, and seal in the impeller), replaced the stator gasket and the water pump gasket. It no longer leaks from anywhere. However, I went to put water in it, and the water ran straight into the crankcase and out of the drain plug almost as fast as I could pour it in. This is without running the four wheeler and prior to adding any oil. The spark plugs are dry, which tell me nothing is getting into the combustion chamber. I would think without it running water could flow uphill to the heads anyways. Anyone have any ideas??
Old 07-15-2018, 08:34 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
or this one is even more focused:
https://www.kawieriders.com/forum/
zx6daddypants
07-26-2011 04:31 AM
Robert24
10-30-2010 11:21 PM
pbanx
07-21-2007 04:55 PM
nucci13
08-02-2006 06:34 AM
fullhouse
02-01-2006 04:17 AM
Quick Reply: 2007 Brute Force coolant flowing straight into crankcase
