Overheat help!!!! 2007 Mule 3010 trans
Old Nov 7, 2022 | 02:25 PM
Apep's Avatar
Default Overheat help!!!! 2007 Mule 3010 trans
Need help. I’ve read everything on this forum. Mule is still overheating.
replaced the following:
thermostat
water pump
head gaskets
radiator cap
fan works and switch is good.
I have pulled it up on car ramps to bleed it multiple times. Let it sit overnight bled again the next morning. Bleed screws have antifreeze at them and radiator is full. Drained entire system and started from scratch. Filled the system with a total of 5L of antifreeze. Still every time I run it there is air on the return side and pressure is built at the supply side. No flow and the hoses at the return side do not get warm. Not sure where to look next. Help please
studebaker53
Dec 22, 2022 01:32 AM
Tabaka45
Oct 24, 2020 02:36 AM
Raw57
Oct 16, 2017 04:40 PM
David Formby
Mar 5, 2017 01:25 AM
garyk
Oct 7, 2012 03:43 PM
