Oil in air chamber
Oil in air chamber
I have oil in my air chamber and also in my air filter housing where is this all coming from and is it supposed to be there this is a 2005 3010
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
If it's just some in the bottom, it is likely coming from the engine breather, which will be routed into the air box. No problem with that, it's the way things are. If it's a lot of oil you are probably blowing way too much out of the breather, usually due to overfill or if the rings are junk allowing too much blow by. My bet is on the normal oil in the air box due to breather. Also if you have an oil wetted foam filter there will be some drainage from it too. There ya go.
progunrunner
06-20-2007 03:52 AM
YYY.GUY
03-29-2007 10:11 PM
