Mule transmission swap
Just got a 2002 Mule 3010 4x4, it came with a 2wd transmission. Is the 2wd compatible with the 4wd minus the trans case thing. Are the gear ratios the same, the 4wd transmission has metal shavings in it so not sure what condition it is in and was hoping to swap it with the 2wd and just add the 4wd transfer case part.
Thanks for any help Rick |
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums or this one is even more focused: https://www.kawieriders.com/forum/ |
