Mule Pro tires on a Mule 4010 Trans?
I found a great deal on a new set of Mule Pro tires and rims (take off). Has anybody tried to mount tires from a Mule Pro on a Mule 4010 Trans? I understand that I will need a 2" lift kit to provide the extra clearance which I want to do anyways.
My main concerns are: 1.) are the bolt patterns the same? (10" rim vs 12" rim) 2.) Is it ok that the front tires are not as wide as the rear? (tires from PRO are 26 x 11 R12 Rear and 26 x 9 R12 Front) 3.) Will the tires rub when turning? Thanks in advance! |
Just an update for anybody else looking to do this: I learned that the bolt pattern IS DIFFERENT on the Mule Pro models vs the other Mules, so you can't just bolt up Pro rims on a standard Mule.
