Mule 4010 no crank over
I went to pull my mule out of the barn the other day and it will not crank over. It was ran 3 days prior. lights come on when the key is turned but cant get machine to crank over, yup its in neutral. Any thoughts? Also if the battery ends up being smoked are there any battery upgrades i can or should do while im there? thanks
Hi ,
Check Under The Seat . All The Wiring . The Fuses . The Ground Wire On the Engine Back To the Battery . Neutral Switch On the Transmission . Under the Dashboard If Take Measurements of your Existing battery , You Can Find A Better ( Higher Cranking Amps ) In The Same Size Battery box . Those " Metric Battery Ends " Are Prone To Corrode Bad ! |
Look in mail for crankshaft recall notice
I am just taking a shot here...but Kawasaki has just issued a recall and inspection on a large number of 2018 & 2019 Mules (4000/4010)
Could you be a victim? call 866-802-9381 with your VIN number or call your dealer |
