Mule 3010 - ok to run with front axles removed?
Morning,
I have a 2006 mule 3010 trans. It is 4WD but the driveshaft to the front diff have been removed since I bought it so it is effectively 2WD. I recently replaced the front axle on one side but I am still getting some noise and pulling. My question is, can I remove one or both front axles and run it like that at least temporarily to determine where the problem is, or will that cause problems. I live it Central America so it takes a while for parts to be shipped from the USA so want to be sure I narrow down the culprit before ordered. A question on front wheel bearings as well. Are those generic and if so does anyone have the specs or part number for something that will work? Thanks Allan |
The front brake drums are press fit onto the axles and will not run with the axles removed. If you disassembly a couple of CV axles, you can install the wheel end and run it like that.
