Kawasaki Mule 4000 october2020
Old May 20, 2021 | 02:45 PM
Ian Sinclair's Avatar
Unhappy Kawasaki Mule 4000 october2020
First of all thank you for allowing me to join your Forum I hope you can shine some light on this problem, I have a Mule 4000 2020 model and I noticed a clicking noise from front hubs when turning. I removed front wheels and found that although hub nuts were tight I could pull and push the front brake drums approximately 1/4 "
I removed hub nut and found that the shaft splines were actually protruding out past the drum centre as if either the shaft was too long or there was a spacer missing not allowing the nut and washer to secure the drum to the shaft correctly. The Mule has done 500 hrs and I have had the Mule since new from the factory, the hubs have never been removed so I am actually wondering what is going on. Any advice would help. Thank you,
Ian
Old Jun 26, 2022 | 03:19 AM
Johnno111's Avatar
Hi,
I am having the same issue, reoccurring with my mule. The mechanic fixes is and it keeps happening again. To the point that it can not be driven.
did you fix the issue? Any advice appreciated
graeme quensell
Jun 26, 2022 03:20 AM
TRazzo
Jul 10, 2020 02:19 AM
mrbailey959
Sep 17, 2019 04:31 PM
william bunt
Jul 23, 2017 10:16 PM
Moose08
May 11, 2010 01:52 AM
