Ignition switch wiring
Hi,
I lost the keys for my 2510 mule and replaced the ignition switch with one from napa. The old ignition switch had 5 wires coming out of it, but the ignition I got has four terminals (batt, ign, st, and acc). I found a post describing hooking the white to the batt, brown to ign, and bk/w to st, but I don't know where the w/bk or bk/y go on the ignition switch. I found a wiring diagram that shows where they lead to, but not which terminal they connect to.
Without those wires hooked to anything, the mule starts and runs, the lights work and the fan works, but the battery drains when the mule sits overnight, which only started after the new ignition switch. It must have something to do with the wiring, any ideas would be greatly appreciated!
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
