4010 Mule....no gas pedal response??
Does anyone else have this random unexpected occurrence? I have a year 2016 4010 trans mule and periodically if I come to a stop and then get ready to take off, there is absolutely no throttle response. I can push the pedal to the floor 10-15 times and no throttle or change in engine RPM whatsoever. If I then turn off the engine and let it set for a minute, then it will start up and proceed with throttle response. Any recall for this? Malfunctioning part? I can giggle the shifter and no change whatsoever.
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums or this one is even more focused: https://www.kawieriders.com/forum/ |
Check the secondary throttle plate. Make sure there is not carbon buildup preventing it from opening, closing or sticking. When you shut off the machine and restart it the actuator moves this plate to a new "initial" position.
