Mule 4010 - Turn Engine by Hand
Old 09-24-2018, 04:43 PM
cbogle123's Avatar
Default Mule 4010 - Turn Engine by Hand
I have a 2018 Mule 4010 and I am trying to figure out the easiest way to turn the engine over by hand so that I may find TDC to do the valve inspection/adjustment. I have the factory service manual but do not wish to follow it by disassembling the stator cover to use the timing marks as a reference. I prefer just to pull the plugs and the valve covers, and use a screwdriver in the cylinder to get as close as necessary to TDC to do the valve check. I'm looking for a shortcut...I know how to find TDC without the timing marks, I know how to do a valve check/adjustment. I just can't figure out if there is an easier way to turn the engine over by hand without the disassembly called for in the service manual. Thanks,
Old 09-25-2018, 07:31 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
or this one is even more focused:
https://www.kawieriders.com/forum/
Paul Leischner
01-14-2019 08:32 PM
Yami Oquendo
07-09-2018 03:27 AM
Green Truck
04-24-2018 06:00 PM
Tomstoys
02-13-2018 12:36 AM
njordan
01-25-2018 03:40 PM
Quick Reply: Mule 4010 - Turn Engine by Hand
