'07 3010 Mule
Greetings I have a question for ya'll. I have the opportunity to buy an 07 3010 which is in rough shape for $1200. It runs, and just needs some tlc and painting. It's a 4x4, four seater. Is this a good deal, I know the carb needs to be cleaned out.
Hi ,
How Many Miles Does it show On the " Speedometer " ( is it Working ? ) . How Many Hours Does it show on the " Hour Meter " ( is it Working ? ) Is the Engine Making Any Weird Noises ???? If you can drive it , Does it take off slowly/ smoothly ? or as the Engine revs up above idle Does take off with a JERKY Motion ? ( Means Clutch work ! ) Shifts ( easy or Hard ) in and out of gear ? if you can , look At the drive - line Parts ( All drive rubber boots ) On all ( Front and Rear ) the Axles , Check the front Drive " CV- Joints ( Inner and Outer ) If Torn or Showing Grease ,$$$$$$$ Big Repair Bill $$$$ .... Next , The Rear Axles , The rubber Boots ( Inside is A Slip Shaft ) , Inner And Outer U-Joints . If you can , move it to a solid surface Parking Lot , Drive Tight Circles Left And to the Right Going Forward and reverse ( NOT DONUTS ) Very Slowly , AND LISTEN For Clicking, Popping Noises , Coming From the front drive or rear , Or The Center Drive Shaft(s) ..... Last Item , Frame Damage ? Any thing Bent / Twisted ? Underneath , From the middle of the machine There is a " Cross-Member " It Holds the center drive shaft(s) ,,,, If it Is """Pushed_UP Against the Floor ,, Bent Frame or Bent Drive Shaft(s) Sorry to be SOOOOOO Evel Good Luck , Later, Mark K |
