-   Kawasaki Mule (https://www.kawasakiforums.com/forum/kawasaki-mule-57/)
-   -   06 Mule 610 Clunking 4WD (https://www.kawasakiforums.com/forum/kawasaki-mule-57/06-mule-610-clunking-4wd-46770/)
mrbailey959 Sep 16, 2019 08:49 PM
I have a 2006 Mule 610 and it has an awful clunking noise whenever it is put in 4WD. It sounds like it is coming from the front end. Sounds like a broken drive shaft. Does anyone have any idea what this may be?
paulj. Sep 17, 2019 11:54 AM
you may have a bad cv joint. i would recommend putting the mule on blocks or jack stands and put it in gear and try to locate where the clunking is coming from. you may just be able to spin the wheel's while jacked up to find the problem without starting it.
mrbailey959 Sep 17, 2019 04:31 PM
Thanks PaulJ. That's my plan. I sounds like a broken u-joint or something like that.
