05 3010 diesel 4x4 keeps losing front wheel bearings?
Hey guys, I got 2 05 mules and i keep losing front wheel bearings. I have replaced bearings shims spacers brake drums repeatedly. Actually replace wheel bearings and seals 3 days ago and already grinding. If i torque the axle nut to the 140 ft lbs the wheel wont even turn by hand. .I have had best luck around 50 ft lbs but still does not last long . Talked to local dealer and they have no idea. I have literally replaced a dozen wheel bearings in the last 2 years. Any one else have this problem ? Any one have an answer or suggestions ?
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums |
