4010 Mule tranny rotation direction confused
Old 06-13-2018, 06:11 PM
Yami Oquendo's Avatar
Default 4010 Mule tranny rotation direction confused
So after downloading many manuals, I still can't figure out when and how the inner/outer drive shafts interact or engage each other. Is the outer shaft always engaged by the high gear and thru the reduction gear within the hi low gear mechanism ? This has to be true because the fw/rev shifter has to engage this outer shaft at all times?Or is the outer shaft engaged only when in low gear? What happens in low gear??does reverse work in high gear...? Does the hi low shifter actually change what output shaft rotates? I know I'm close to understanding, but need clarification
Yami Oquendo
06-14-2018 05:47 PM
babu
09-11-2017 02:35 AM
dcg9981
11-19-2015 01:37 PM
dcg9981
11-19-2015 01:22 PM
Older Not Wiser
08-04-2009 10:27 PM
Quick Reply: 4010 Mule tranny rotation direction confused
