Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
wiring
Old Oct 31, 2019 | 01:14 AM
zoomzoom's Avatar
Default wiring
i have a 1996 kawasaki zxi 900 jet ski......
i want to rid the jet ski of all of the gage dash wiring & simplify things..... anyone done this before, i will cover the round gage holes with a custom varnished piece of wood.....
i want to be rid of all the excess wiring.......
thank you.
Old Jan 17, 2020 | 08:20 PM
Dan Westlake's Avatar
The gauges are integral with the CDI unit as they monitor oil and water temps. I don't think that the ski will function without them.All are fed through the trim motor first on the red/gray wire wire and then out to the Main fuse block in the CDI enclosure on the orange wire which goes to a junction block connector under the dash above the gas tank.The power for all your gauges are fed from this point but also run to the cdi unit where they get their information as to fuel,oil and water temperature conditions.. I will post the wiring diagram for you.It's for the 1100 but should be the same for the 900
Dan Westlake
Jan 17, 2020 10:15 PM
zoomzoom
Oct 31, 2019 01:32 AM
tjohns
Oct 10, 2017 01:02 AM
PerchLane
Oct 19, 2012 09:59 PM
arrazorhog
May 22, 2006 11:52 PM
