Problem with my Kawasaki 750 Xi Sport
I recently bought a 2000 Model Kawasaki 750 Xi Sport Jetski. Looks and starts great. Only problem is that when I run it oil appears under the engine in the hull? It seems to be clean oil? All the hoses seem to be OK? Its a mystery? Can anyone make any suggestions? Thanks Simon |
RE: Problem with my Kawasaki 750 Xi Sport
Not sure if same as older 750's? If you have the drain on crankcase make sure that is closing up. Freind with a xir 750 had same problem we blocked it off no more oil/gas in hull. Looks like a primer plunger on exhaust.
Thanks mate. Got it in one! It was the crank case drain valve leaking. Put in a blocking plate. Good as new! |
[sm=smiley20.gif]
| All times are GMT. The time now is 10:49 AM. |
