Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
98 1100 a lot oil coming out of pipe in nthe back
Old Jan 20, 2008 | 01:51 AM
chelemix's Avatar
Default 98 1100 a lot oil coming out of pipe in nthe back
hey i need help guys i have 98 1100 just go it and it start and run bout it seems to be shooting a lot of oil in the back a lot and a lot of smoke please help it is the oil pump can i changed to premix it ihard to do it ? thanks for any help
Old Jan 20, 2008 | 06:01 AM
kx slaughter king's Avatar
Default RE: 98 1100 a lot oil coming out of pipe in nthe back
is it a 2-stroke?
Old Jan 20, 2008 | 01:59 PM
chelemix's Avatar
it is a jetski 98 1100 a two stroke engine
Old Feb 9, 2008 | 01:32 PM
apachetorpedo's Avatar
ORIGINAL: chelemix
have you changed to pre-mix yet? if not its very easy to do and will give you piece of mind. let me know and i can step u through the process...Apac.
Old Feb 11, 2008 | 02:32 PM
chelemix's Avatar
thanks you are a blesing some one told me it maybe a piston problem i just checked the conpresion put my finger in top of the cilinder and all 3 are the same bout please tell me how i will follow instructions
Old Feb 11, 2008 | 07:05 PM
Kohburn's Avatar
you need a compression tester gauge - your finger can' tell the difference between 90 psi and 150 psi
Old Feb 12, 2008 | 02:03 AM
yes you do need a comp. gauge your fingers just dont cut it for that kind jobzxi's smoke alot anyway in my book-your oil inj.settings on carbs may need adjustment . here is a link for a block off plate- this is the first step http://www.parkeryamaha.com/index.as...p;ProdID=18405
Old Feb 12, 2008 | 10:34 PM
chelemix's Avatar
hey i have good finger you guys are right bout please have mercy on me im new an i got the block off plate whats next and by the way 3 kids are telling you guys thank you we do not have a lot money to fix the jetski and sumer is coming
Old Feb 14, 2008 | 02:34 AM
you need to remove oil tank / oil pump and lines to tank and carbs, your B/O plate kit should have come w/caps to put overoil inlets at carbs/ then install plate ..make sure the o-ringis on plate and should be good to go[8D]
Old Feb 14, 2008 | 07:03 PM
chelemix's Avatar
hey it work thank you so much muchas gracias i had it on the water i was freasing bout it run fine 2 persons and it pick up up to 45 50 mph for me thats fine i premixed at 50 to 1 it thats fine or should i use diferent graciassssssssssssss i know it may look simple for you guys bout im new at this thanks mr apachetorpedo big help know how do i fix the title (just kiding )
