650 TS jet ski hard to cold start
It take me about 10 minutes to start the ski. It runs fine after it is started but doesn't seem to be getting enough gas to cold start. If I spray carb cleaner in carb throat it will cold start right up every time.
Roy |
RE: 650 TS jet ski hard to cold start
you need to install a primer kit. It will deliver gas for a cold start. Works great and saves your starter.
Same here, my 650TS just needs to be started on the trailer first (For 10 seconds) to get some gas to the engine.
Then in the water it starts right up. It is a gas delivery problem. |
you need one too.
Pump the primer bulb for about 30 seconds...I used to have a TS and it did the dame thing...once I primed the bulb then cranked it it was good to go for the day
Instead of installing a primer kit which looks kind of involved to install can you put a primer bulb in the gas line to the carburator?
