Zl 900
Old Feb 2, 2008 | 03:28 AM
BlueCoyote's Avatar
Default Zl 900
Can I use ninja carbs on my ZL 900 ? some @$$hole vandalized my bike smashing the carb assembly with a hammer or something and I need to replace, however im pretty hard up for cash and need to know what options I have for fixing it
Old Feb 2, 2008 | 05:04 AM
whitehendrix's Avatar
Default RE: Zl 900
as long as the carbs meter the appropriate amount of fuel into the motor, yes.
if they're off a ZX9-R or something of that nature, they should be sized well enough to give the correct A/F ratio...
you may have to play with jetting to acheive perfect A/F tho.. and they'll need re-synced to your bike..
were the carbs smashed while still on the bike?! i 'd check to make sure theres no bits of metal and plastin in the intake runners, or inside the piston (thru an open valve)
and welcome to KF, bro!! good luck on that, and keep us posted.
Old Feb 2, 2008 | 07:23 PM
Default RE: Zl 900
Dang, vandilized carb only?
Not sure what the carbs are on this ride. If it is the same model, jet and set up similar to the others and resync like wh mentioned. Good luck.
Welcome to KF
Old Feb 3, 2008 | 02:40 PM
Bluebeast's Avatar
Default RE: Zl 900
it sucks about some one doing that to your bike. Not to sure about the carb if it will work but maybe try what the other guys have said and see if that works. And by the way welcome to the site.
wicked900eliminator
Aug 6, 2006 06:37 AM
900A2
Jul 23, 2006 04:13 AM
guyzer3
Jul 17, 2006 08:36 AM
sasha
May 8, 2006 09:11 PM
seats
Mar 30, 2006 03:37 AM
