| RonInFla |
Sep 22, 2008 05:09 PM |
Yep, It's usually the thermostat. It's on the back side of the radiator at the top right side.
It's got 1 wire on it. (there's actually 2 sensors there, but the inner, closer to the hose connection, is the warning lite sensor) Pull the connector off, and using an extra piece of wire, ground it to the "frame". The fan should come on. If it does, replace that sensor (also called the "fan switch") $30 to $50.
Now, if the fan didn't come on, try grounding in different spots on the frame, 3 or 4 times. If the fan still doesn't run, check the fuse. Inside the fuse panel cover, there's a list of what fuse does what. And never use a bigger fuse than you take out.
