Vn1500D Spark Plug Wires
Need suggestions for after market replacement set of spark plug wires for vn1500d. OEM wires are no longer available from Kaw. Suggestions as to 7mm, 8mm, 8.8mm and solid conductor vs. resistor wires. Also, how to handle the deep set plugs...135 degree sockets vs. straight etc.
thanks!
thanks!
RE: Vn1500D Spark Plug Wires
Welcome to the forums... Can you give us a little more info on the bike.. year? etc.. and I can do some research for ya..
If you have a radio on the bike, or it has a computer you definately want the resisitor wires...If your plug wires unbolt from the coil, you can make your own.. Accel makes a universal motorcycle wire kit for around $65.. you just trim them down yourself.. real easy to do.. If your bike is like mine, the plug wires are built into the coil....
Enjoy your stay!!
Enjoy your stay!!
