VN1500 Classic 1987 timings problem
Old Aug 13, 2021 | 05:03 AM
mihaimarton's Avatar
Default VN1500 Classic 1987 timings problem
I need your help! On a 1987 Kawasaki Vulcan VN1500 I adjusted the timing like this, first the front cylinder to the F sign then rotated 310 degrees counterclockwise and I adjusted to R as seen in the pictures. It's good? The engine does not start! Backfiring into the carb.
The engine has been rebuilt, there is a spark, the fuel is fine, it has compression (new rings), the crankshaft rotates fast enough, my only ambiguity at the moment is: there is a possibility that the spark can be out of sync with 360 degrees, to spark when it evacuates not when it is in compression?
Klxster
Apr 3, 2023 02:42 AM
piratelife
Mar 12, 2017 07:04 AM
Klxster
Oct 7, 2016 04:08 PM
Jestr8
Oct 2, 2010 09:48 PM
sacwb
Jun 30, 2008 04:30 PM
