Trouble getting to battery
Old Oct 10, 2006 | 09:10 AM
spooknick's Avatar
Default Trouble getting to battery
Hi all well here it goes the problem is i just bought a 99 zx7 with 11,000 miles on it and it does not crank all the time like every morning the temp outside is around 55 to 60 and when i do the chock it runs, but when i take the choke off it turns off again. After about 5 attempts every moring it finally runs im not sure if its the battery or not i just had a tune up but he did not check the battery is there any suggestions i should to and also how to i get to the battery is it under the seat cause i have no idea. I tried looking removing the seat but it seems like im going to brake it PLEASE somebody help me
THANKS FOR ALL THE HELP
Old Oct 10, 2006 | 05:43 PM
srobak's Avatar
Default RE: Trouble getting to battery
If it is cranking over, then your battery is fine. Most carbed bikes need to run choked for a few minutes until they warm up to operating temperature. What I do is start it choked, and while it is warming up choked, I gear up, attach my luggage (laptop bag under cargo net), etc... double check things like chain slack, tire pressure, etc... after those tasks (about 3 or 4 minutes total), then the bike is usually good to run. Slowly back off the choke and let it idle just a moment more without choke... then you should be good to go. First starts in the morning are usually the most difficult. Let it idle choked for a couple minutes and you will be fine.
As for seat removal - remove the rear seat, and inside the tray there is a pull-cord for the front seat. Pull and hold this cord while lifting the rear of the front seat. That should do it.
Old Oct 11, 2006 | 06:27 AM
I believe in the 5 minute rule on start ups and warm up times.
My '90 starts up in a hearbeat, so kinda curious on the extra attempts in starting.
Old Oct 11, 2006 | 06:45 AM
spooknick's Avatar
Thanks on all the info guys i did find the battery and also took the bike to Fun Machines aka the Stealership come to find out the battery was in the bike for over 8 months with min. cranks from the prev. owner, it looked so bad that there were spiders inhabiting the battery compartment with dirt and a couple of dead ants.
NinjaColin
Apr 29, 2009 02:53 AM
amart47
Feb 22, 2009 10:03 PM
Finger Mullet
Jan 16, 2008 08:38 PM
sam
Dec 3, 2007 03:07 AM
jayden
Apr 29, 2006 10:16 PM
