throttle or carb problems
the throttle on my '78 kz650 is going crazy. when i clutch between gears it revvs up to about 4 grand and stays there for a bit, then eventually goes down to idle and dies if you let it idle too long. its definitely not me doing it by accident. i know that someone who owned the bike before me had the bright idea of boring out the carburetor jets to get more fuel, but now it runs too rich. do you think that could be why the throttle cranks by itself like that? i ordered some pod filters to replace the intake box, with hopes that getting a little more airflow will help smooth out the mixture. is there a way to turn down the fuel ratio on the carbs? any suggestions would be helpful! thanks
RE: throttle or carb problems
also the warmer the engine gets the worse the problem gets, it revvs up every time you clutch and once it idles it dies almost instantly
Don't know if this would cause the problem but..........
My '81 KZ 750 LTD was having a problem............... It would run fine for a while and after a few miles, once it was warmed up, it would lose power. The problem was improper suction of fuel from tank into the carbs. The mechanic removed the valve /switch that controls flow from tank to carbs and rebuilt the mechanism inside (it is located directly under the gas filter inside the tank) If this isn't functioning properly, couldn't it cause the flow of gas to increase and decreas randomly, causing the revving and stalling you describe? Maybe someone knows more about this than I and can describe it better. Good luck |
Actually, it's running too lean. Engines like to race when they have a lean A/F ratio. Too much gas causes them to bog down. Small engines such as motorcycle engines tend to have more dramatic aftereffects from small changes like an aftermarket pipe, or a modified airbox. It is also very possible your float bowl levels are way too low. That too would cause a lean A/F condition.
ORIGINAL: davehayward1 Don't know if this would cause the problem but.......... My '81 KZ 750 LTD was having a problem............... It would run fine for a while and after a few miles, once it was warmed up, it would lose power. The problem was improper suction of fuel from tank into the carbs. The mechanic removed the valve /switch that controls flow from tank to carbs and rebuilt the mechanism inside (it is located directly under the gas filter inside the tank) If this isn't functioning properly, couldn't it cause the flow of gas to increase and decreas randomly, causing the revving and stalling you describe? Maybe someone knows more about this than I and can describe it better. Good luck |
Un synched carbs can cause similar issues as well.
great. i dont know how to fix those problems... it doesn't make sense that its too lean though, if the carb jets are bored out... does it?
i'm not much of a mechanic and i've never worked on a bike before, but i do enjoy getting my hands dirty. is there any way to adjust and sync the carbs that i can do without paying someone alot of money to have it done at a shop?
bored out jets. Good point. so install stock mains and try to get a baseline.
It could be somethingnon jet related tocause the engine to lean out though. It isn't always the usual suspect. Your engine having a hard time returning to idle is a classic example of running too lean. But having said that, it still COULD be something else, but not very likely.
