sitting for a year
Old Jul 4, 2008 | 07:43 PM
znmego's Avatar
Default sitting for a year
hello, my cousin's bike has been sitting for a year and he was wondering what we should do to get it started again. any advice would help us out a whole bunch. thanks.
Old Jul 4, 2008 | 07:54 PM
jeffzx9's Avatar
Default RE: sitting for a year
Drain gas and oil, replace with fresh. Leave battery on a long, slow charge; not the "quick start" zap! Pull the plugs and putseveral drops of oil in each cylinder. (I would change the plugs while I had it that far, but probably not necessary.) With bike on rear stand, give the chain a good cleaning and a light coat of preferred chain lube. Check tire pressures. Once started, let it run until warm before putting load on the engine, just to make sure fluids have successfully returned to their designated pathways. Check coolant level and overflow. Once warmed up, check for leaks. Should be good to go.
Old Jul 4, 2008 | 09:05 PM
Nice info jeff.
Clean the ground connection at the same time. I would prolly flush the coolant passages prior to changing as well. Also, 1 yr on fuel metering systems plays hell, so ya may want to clean carbs or system as well.
cougarkid
Oct 3, 2007 10:04 PM
negoshe8n
Jun 15, 2007 04:56 PM
suprakawigrl
Feb 18, 2007 06:40 AM
incabiker
Jan 31, 2007 07:47 PM
kas20002004
Dec 25, 2005 01:06 AM
